Polish & wax job turned out to be a disaster.
I think a few things went wrong.
I used the classic #7 polishing compound and Mother's synthetic wax.
I used that small foam ball with drill on MAX speed.
I removed all the polish, and then waxed. Wipe on, wipe off.
Car looks great! Shiny.
Then, it rained 5 hours after.
The only stuff that remained was a little white here and there in the cracks.
Well, in the rain, it all washed out and smeared everywhere.
Like 10 birds crapped on it. Car was a complete mess.
It's impossible not to get some product in a few cracks, and if this is what happens when it rains, I am never polish/waxing my car again.
After rain, white residue was also splashed onto every piece of black trim.
The rain seemed to have splashed it all over the trim.
Car looks like it has mold all over it.
It wasn’t like this when I was done waxing on the car.
It doesn’t come off by simply wiping like on the sheet metal.
I bought "Back to Black" and scrubbed it hard, and the trim looks a lot better.
I'm not sure if the white stuff was the wax or the polish. But, now I am guessing it's the polish.
I was able to easily wipe it off the sheet metal, but there is white splattered **** in every nook of the car. (weather seals, door seams you can reach, etc)
First, I think I used way too much polish.
I just smeared some onto the panel, used the foam ball to spread it around, and then swirled until mostly dry haze.
But, I think it got jammed into every crevice, and I must not have removed it from crevice like under the trim, weather stripping, etc.
Looking back, I think it was a mistake to smear up the entire panel before polishing.
After I while I noticed the drill attachment would create white haze even without adding polish, b/c the attachment was now partly damp with polish.
Is it safe to just go over new dry paint without adding explicit polish if the drill attachment has enough polish loaded to automatically haze up the paint?
This seems much cleaner, uses less product, and makes less mess also.
I also swirled the hell out of the paint.
I thought you could only get swirls from compound, not polish. Wrong.
Went in both directions, but it might have been spinning too fast.
No idea how fast you’re supposed to do it.
No idea how fast the DA polisher goes.
I think another case of using the wrong tool.
I used the DeWalt drill at maximum speed, once the polish was hazy.
Regardless, entire car has buffing stripes all over it now, in the proper reflection.
Not sure of next steps.
I will try to compound out a section by hand, and see if it works.
This was a huge disappointment and the car is worse off than before I did anything.
