Hi. Why it is good to use foam gun? I wash my car use two bucket method, why is it good to buy foam gun as well? does it improve washing in any way? thks
washing by hands vs foam gun
Re: washing by hands vs foam gun
Well, it is just different, not necessarily better or worse.
I like to be able to add extra soap (lubrication) to the surface easily when I feel like more is needed with the foam gun. I also like that I can cover the whole panel in soap, to make sure there is lubrication everywhere, and not just running off right away.
But, those are really just personal opinions. It is not like the dirt magically flies off the paint or something from using a foam gun.2017 Subaru WRX Premium - WR Blue
Foam gun is good to loosen the grim/dirt/caked dirt. Once it got loosened, you can safely remove those without marring the surface. So, its good when your car is so dirty. Otherwise, you can go for normal TBM.
If you are going to do full detailing, then foam wash -> TBM -> detailing process.Megaddict
