My Smooth Surface Clay Kit arrived today. I noticed it contained a bottle of Quik Detailer spray. Would Ultimate Quik Detailer be a better product to use for the claying process?
Claying Question
Re: Claying Question
Well, the UQD costs more, so a bit of a waste. But the UQD also leaves a very slick polymer coating on the surface. So you are basically spraying the dirt you want to remove with a slick protective polymer, and then trying to remove it.2017 Subaru WRX Premium - WR Blue
Originally posted by Murr1525 View PostWell, the UQD costs more, so a bit of a waste. But the UQD also leaves a very slick polymer coating on the surface. So you are basically spraying the dirt you want to remove with a slick protective polymer, and then trying to remove it.
UQD is too slick for the claying process, and the durable polymers in it could actually impede the claying process. We put good ol' Quik Detailer in the Smooth Surface Clay Kit because it's the best choice for the job.Michael Stoops
It would be mighty helpful to have a product list with attributes or features check list so that this info can be referenced easily.
Even a list for all the megs sprays would be helpful...
There seems to be a great wealth of info but somewhat scattered.
Does Last Touch have the polymers?
Originally posted by Murr1525 View PostWell, hanging around here way too much helps...
But I think the bottle/description also says that UQD leaves a polymer coating behind.
QD, LT, or FI are your main claying sprays.
But even when the bottle said that I personally wouldn't have come to the conclusion your post makes where you say by using UQD you are basically adding those polymers to the dirt then trying to remove it...
To me I would have read the bottle and thought the polymers some how assisted the dirt removal process.
Every time I take a step forward I seem to take two steps back in my understanding
ONR has polymers as well...lots of people use it as a clay lube"STRIFE" aka Phil
I rarely visit just www.meguiars.com. After you select a product and go to its page...it has some icons that state product benefits/features. This is kinda what I was looking for.
