m205
  • m205
    When using m205 with a yellow pad and a da on speed setting 5 I get fine swirls after I was the vehicle. Initially they are there and just can't be seen because of the gloss but after a wash it is obvious. Do I need to re-compound the vehicle or can I try 205 again with a black pad at the same setting since it still has some abrasives in it?? Do you think that the yellow pad may be too abrasive or is it the yellow pad may be dirty. I clean it before use in a washing machine and then delicate dry with nothing else else in the dryer??
    Re: m205
    Can you say some more about the vehicle.. paint ,color ,etc?
      Re: m205
      You may not be removing the original swirls completely, but covering them up with the oils that are in 205, and when you wash the car and the oils away, the swirls reveal themselves again.
        Re: m205
        I use the yellow pad with compounds (105/UC ) and the finishing pads with polishes ( 205 and UP ) . When compounding with a D/A/orbital, I use speed setting of 5 and for polishes a speed setting of 3. The speed and pad selection give you the cutting power. You should always start by doing a 2' x 2' test area to check the selection of pad and product are achieving the look you are after. Doing a test area will allow you to use the best combo of pad and product, you want to use the mildest combo to get the results you want.
        BMW ZSCCA Area Rep SoCal
          @chz06
          I removed every thing initially but instilled swirls when applying the polish whether it came from a dirty pad or too aggressive speed/pressure of my technique. The vehicle is a black Infiniti g37s
            Re: m205
            Sounds like the paint is soft. Try following it up with M205/W9207 black finishing pad.
              Re: m205
              On my 2003 black Honda Accord, I used M105 with a yellow Lake Country pad to get the swirls out. No more swirls. Then I follow up with M205 with a LC black finishing pad. You might be trying to work to big of a area at one time. That was a mistake I made the first time I detailed my car. No more than a 2 x 2 area and remove the 105 before it dries, make sure you keep the pad clean. another mistake I used to make.
                Re: m205
                ^^ This.
                  Re: m205
                  I recommend trying a test spot and verifying your results there. We can suggest combinations until we are blue in the face, but in the end you will need to test things out and find what works on your specific vehicle as no two are identical.
                  I would start with a finishing pad and M205 and see if that works. If it doesn't seem to do anything then you can work your way up to something more aggressive and determine if you are either not fully removing the swirls that were already there, or if the the polishing pad is introducing something new.
