First detail ever!!!!
  • First detail ever!!!!
    So I've been trying to learn all I can over the last month and building my product collection. I even went to a TNOG to learn some technique but it was super busy that night to really learn anything. Today I tackled the front portion of my explorer. Thursday I washed it. Friday I Clayed the whole car. And today I used UC, UP, and ULW all by hand. When using the UC I put it on using MF pad and a terry cloth pad. I rubbed it in with some passion and only a small section at a time. It wasn't on there for more then 4 minutes. When I tried to wipe it off it would come off. I tried rubbing longer but there was still product left on car after wiping. I had to REALLY SCRUB hard to get it off. Is this normal? I just thought my paint was dry or something but the same thing happened with the UP. I had to use QD to get the residue off between products. I even tried to use less product on application but it still did it. I was in shade with car cool to touch. Help please.
    Re: First detail ever!!!!
    Also I just noticed when I moved car into sun I can see my wax 'strokes'. How do I get rid of that? Also how long should I wait to apply another coat? Thanks for the input
      Since UC is a compound, there is really no use in letting it sit on the paint. It will just make it more difficult to remove and it doesn't accomplish much of anything. As for the was strokes, maybe you applied too much wax and didn't get it off properly? What were you using for an applicator, how long did you leave it on, and what method did you use?
      Ryan
      ~Ryan
        That's the thing. I didn't let the UC to sit. I worked it into paint to wiped it off right away. I prob worked in in for 2-3 minutes at a time and wiped it off. For the ULW I used the black applicator it came with. I tried not to use to much but I wiped it off with the black towel it came with and followed up with an ultra shine towel. I let it dry for about 10 minutes then wiped. Should I just go over it again with a MF again and use more pressure? If I put another coat on will that help?
          10 min may not be enough to dry depending on the weather. When I lived in Texas I had to wait at least 45 minutes because of the humidity. Also UW uses thin layer technology for application, a little goes a long way. A proper thin layer should wipe off easily once dry. For the streaks it probably wouldn't hurt to take a MF towel and UQD and wipe it off. Wait about 12 hours for the wax to bond to the paint and wax again.
          2010 F150 FX4 and 2001 Ford Escape
          Meguiars All the Way!!!!!!!
            Ok so today I tried my door with UC,UP,and ULW. Same thing happened. I even made sure to wipe off while it was still wet. From the time I put it on applicator to time I finish wiping off was less than 2 minutes. Still had a lot of residue left. I even use QD to wipe off rest of residue before going to next step and i had to do that twice to get residue off. What am I doing wrong? It's frustrating and I've used almost a whole bottle of QD just wiping off residue. Trust me I put some passion into wiping off UC and still was left on there. My arms are sore today. I'm 6'1'' and weigh 270 also play baseball and kickbox. I mean I really had to scrub to get that stuff off. Please somebody help
              What was the temperature? The only thing I can think of is either you're using too much product or the surface temp was too high. Once it dries it is hard to get off and it will leave some residue. I used UC yesterday and had no issues. If you're going to be doing a lot of compounding I suggest investing in a DA polisher to make it easier on your self.
                It was about 80 degrees around 730 pm in California. Surface wasn't hot and it was in the shade. I'm saving up for a DA. I'm supposed to buy my buddies but he's been lagging on it. I think I'm just gonna try to go to TNOG soon to correct my technique. I'm just so frustrated right now
                  When i run into the problem you have its normally to much product is the reason.
                    Working by hand can be a bit tricky at times, depending on the age of the paint, the applicators you're using, amount of product, size of work area, etc. Please do come down to our next TNOG (it's on the 28th of this month) and we'll make a point of getting you in the garage and working on your technique. Don't be shy about grabbing when you arrive and talking about this. Sure, these sessions can get pretty busy, but this is the exact sort of reason why we conduct them in the first place.
                    Sometimes just a small tweak to your technique can make all the difference in the world. We'll work on this together and make sure you're happy.
                      Try giving your bottles of product a good shake before using them next time , maybe that will help . Its possible that some ingredient separation could have occurred in the product .
                        Thanks for all the input guys. I was thinking over everything and I think it may be that I'm using too much product. Although I must say I'm very happy with the outcome of my shine. Lol I think I just want it perfect the first time I try. I just have to relax and continue improving my skills slowly but surely. That's why I'm using this car as practice so once I get my new cars I'll have it down. Thanks again for all the input guys. It's really appreciated.
