DA VS rotary polisher in black paint
  • DA VS rotary polisher in black paint
    start with a da but the defects are still in my paint just wondering if i should keep trying the da or switch it up to a rotary the paint has like imbended paint mark in my paint like some washed it then didnt rince of the soap and the immediately waxed it so iam using number 83 then going a swirl remove on a soft buff pad
    if you can give me an ideas if i should switch or what cause iam lost
    Re: DA VS rotary polisher in black paint
    I'd stick to the DA and change the product you're using. Try ScratchX (less aggressive) or Ultimate Compound (more aggressive).
    How are you using the DA? Have you watched the how-to videos?
    Unless you're experienced with a rotary, be very careful using one, as you can damage your paint!
      There are a lot of variables when choosing any liquid, so we'd like to know a few more things about your current process:
      • What speed are you running at?
      • What pad are you using?
      • How large an area are you working on?
      • How much pressure are you putting down on the pad?
      Changing any of these can increase or decrease the overall cutting ability of any liquid. Let's sort this out first before you move on to a rotary, where things can go sideways pretty quickly if you aren't experienced. You've tried just a single, moderate product on the DA, there's a whole big world of options still available to you with that tool.
        i started my regiment as on you open garage
        i washed top to bottom
        clayed the the car it removed some of the defects
        then i washed again
        then i proceed with the da using medium cut cleaner
        then its removed some of the deep defects in the paint but there are those darn etched watcher marks
        so i was going to proceed to use number 83 with a rotary and if that didnt work go to a cutting pad with diamond cut to get to then polish protect
        so i want to ask the pros and enthusiast
        thanks guys i reall wanna havea nice truck to show off to my clients
