My wash set up anything else needed ?
  • My wash set up anything else needed ?
    Tonight I well be washing my mattilic silver Benz doing uw&w full clay ultimate compound on some areas then a12 using the megs microfiber simoniz premium wash mitt megs foam applicators simonz terry wax applicators do I need anything else
    Re: My wash set up anything else needed ?
    No, you sound like you're probably going to be good to go. The A12 will look fine, but you will get more longevity and pop later on by going to one of Meguiar's other waxes.
    Nevertheless, cleaner wax can be great at a first go. It's easy to use and works better than you'd think. I believe the results will impress you if you're following all the steps you posted out above. The claying itself will be the most dramatic step and will leave a clean surface for the A12. Just be sure not to reuse the clay if it ever drops on the ground.
    Good luck!
      Sounds like a good foundation for some NXT2.0 next time around!
      2011 F150 5.0L 4x4
        yeah ill be using ultimate liqued wax after but thats when i get it probaly end of the month
