Tonight I well be washing my mattilic silver Benz doing uw&w full clay ultimate compound on some areas then a12 using the megs microfiber simoniz premium wash mitt megs foam applicators simonz terry wax applicators do I need anything else
My wash set up anything else needed ?
Re: My wash set up anything else needed ?
Originally posted by SunnyD View PostTonight I well be washing my mattilic silver Benz doing uw&w full clay ultimate compound on some areas then a12 using the megs microfiber simoniz premium wash mitt megs foam applicators simonz terry wax applicators do I need anything else
Nevertheless, cleaner wax can be great at a first go. It's easy to use and works better than you'd think. I believe the results will impress you if you're following all the steps you posted out above. The claying itself will be the most dramatic step and will leave a clean surface for the A12. Just be sure not to reuse the clay if it ever drops on the ground.
Good luck!
