hey guys,
did the whole 3 step 2 days ago....and so I wanted to add another coat of tech 2.0 to my hood this afternoon.
At first it was cloudy, but then became sunny, weather is around 70 degrees
It had rained and the hood accumulated some dust and other things, so instead of giving it a full car wash, i wet a MF towel and wiped down with some tap water to take away bulk of dust and grime, then all I did was use the quik detailer and wiped down with microfiber (should I have done this as opposed to a real car wash with soap and water? even though i'm only doing one panel)
i applied the tech wax 2.0 under partly cloudy skies...and left on for about 40 minutes. When I wiped down, I noticed that there seems to be some swirls that I don't know if they were there before....
Did I create those swirls when I "washed" the car using the quik detailer and dragged dirt around the hood when I should have used soap and water? (Although I just did the 3 step including tech wax 2.0 JUST 2 DAYS AGO, so I thought I wouldn't have to do another whole car wash, although I did feel my hand across the hood and it wasn't that smooth....which then i used the quick detailer along with clay bar to try to smooth it out)
do you see the small swirls?
