I am trying to use my Griots Garage DA for the first time and having a little bit of a problem. I'm using Lake Country pads, the white polishing pad with Ultimate Compound. I'm using it on my 65 Mustang which has fairly badly oxidized white paint (single stage I believe). First I washed with gold class car was, then clayed the whole car. Then I did a test spot with Swirl X and one with Ultimate Compound, the UC looked much better so that is what I'm going over the whole car with.
Here's my problem, I'm not able to wipe off all the UC with my microfiber towel. I'm working small areas at a time, and I think I'm using the right amount of product (one ring of product around the outer part of the pad). I've read other threads saying this can be caused by either not working it long enough or working it too long. I've tried going longer and shorter and still have this problem. Most of it wipes off, but there are places that won't wipe off. If i rub it with my bare finger it comes right off, or if I mist it with Quck Detailer it also comes right off.
Any suggestions? Or should I just keep misting it to get it to wipe off?
P.S. after the UC I plan to apply Ultimate Polish and two thin coats of NXT 2.0 Wax.
