emblem cleaning?
    Re: emblem cleaning?
    i don't work for them
      Originally posted by Pro01 View Post
      can i use all purpose adhesive on it??or it should only use car adhesive??i'm afraid it will leave a mark on my car when i want to take 'em off again..
      You probably could use a mulitpurpose adhesive because they are so small and dont weigh much and is not exposed to wind pressure. But make sure the adhesive is not permanent or it might leave a mark when you pull them off again.
      2011 Jet Black 328i Touring
      2007 Jet Black 335i Sedan
        Try using a toothbrush or Q-tip with a little cleaner wax.
        Don
        12/27/2015
        "Darth Camaro"
        2013 Camaro ... triple black
        323 hp V6, 6 speed manual
          @ Gforce..uhmm..i don't think they sells it here..
          @smack & don..thx 4 the tip..i'll try that..
          • #20
            I would take a terry cloth or microfiber towel and wrap it tight around something like the handle of a tooth brush and apply a little paint cleaner like Swirl X or you could try some cleaner wax (depending on what you have) and then you can get in close with the towel covered end of the tooth brush handle to get in close to the emblem and rub that residue off.
            Brian
            • #21
              Take off the rear emblems. Just leave the Audi rings. You will be happy you did. Not only does it look cleaner but you wont waste time trying to get rid of the wax builup around the emblems.
              • #22
                owh..okay..i'll try that..thx evryone for the advice..
