Using Black & Decker KP600 for detailing my car???
    Re: Using Black & Decker KP600 for detailing my car???
    Originally posted by Jefri Lay View Post
    Hi guys,
    Due to limited budget I search some polisher which are not too expensive, but I don't know whether this product can solve my problem.
    Black & Decker KP600 maybe you know this polisher, my questions are:
    1. will Black & Decker KP600 can be used for beginner like me? YES & NO - if u were to Consider its for future investement
    2. can Meguiar's M80 be aplied on this Black & Decker KP600? Sure - what i did was convert the backing plate to velco & got soft buff w8027
    3. can this Black & Decker KP600 solved my problem? (you can see the detail problem in this link http://meguiarsonline.com/forums/showthread.php?t=47876 ) my only suggestion - get the best & forget the 2nd best
    If you had some information about using this Black & Decker KP600, don't be hesitate to tell me, okay.
    Thanks in advance guy for the info.
    Best regards,
    Jefri Lay
    Hi Jefri
    sorry for the late reply - have been busy lately training others, since i injured my elbow,
    I have help a numerous beginners & enthusiast like you
    http://thedetailers.blogspot.com/201...ve-rotary.html
    look at the long term, any of yr friend coming KL or u ? take Airasia & i will get u a makita at RM 820 &
    I went a long detour as nobody explaine started with ROB - borsch then KP600- x 2 units = Makita - the amount of $$$ spent ahahaha
      Nice to see you back, KC.
      I hope your elbow is fully healed.
        Jefri,
        Black & Decker KP600 is an orbital buffer. Only good for polishing and waxing, nothing else, no paint correction ability at all. If you put pressure on your hand applicator with a compound you're gonna remove more paint than with this polisher.
        It has a backing plate build in and you can't remove it. It doesn't use buffing pads, only bonnets which go over the backing plate.
        We lead you the right way, we don't want you to get frustrated with a polisher which doesn't help much.
        Hi greg,
        I have borrowed a friend's KP600 unit like this and was wondering:
        What do you mean you'll remove more paint if you apply more pressure with this unit? Because its just an orbital polisher rather than a DA one?
        Also, I don't really get why bonnets over a backing plate is worse off than a buffing pad. Buffing pad also has some sort of hard backing plate doesn't it?
        Cheers
