Hi all, Can Ultimate Quik Detailer be apllied on glass?? I want to use it for water beading. Thanks in advance.
Applying UQD on glass???
Re: Applying UQD on glass???
Originally posted by rapport25 View PostYes no problem. Go for it!!!
When I give mine a quick freshen up I always spray nxt speed detailer over the whole car including windows/lights//rubber trims etc....
But is there anyone else who has some opinion about this?
I normally use both UQW and UQD on the side and rear windows, no problems.
I normally don't use it on the windshied, only because in the past I've had problems with the wipers chattering and smearing. I use Rainx, and (guessing here) maybe the products don't play nice with each other.
Bill
Originally posted by BillE View PostI normally use both UQW and UQD on the side and rear windows, no problems.
Bill
But Is anybody else ever use UQD on the front Glass and is it good for water beading on the front glass??
I tend to use RainX every so often on all my glass, with UQD/UQW put on in between.
I dont think fresh UQD on my glass is the same as fresh RainX, but its ok.
I dont seem to have problems, but glass, and esp wipers, seem to behave different on different cars.2017 Subaru WRX Premium - WR Blue
The use of UQD on windshields is a very common practice. Just keep in mind that it really isn't leaving all that much behind, so with heavy rain and the action of the windshield wipers, you may not see much of a long range benefit.Michael Stoops
Originally posted by Murr1525 View PostI tend to use RainX every so often on all my glass, with UQD/UQW put on in between.
Originally posted by Michael Stoops View PostThe use of UQD on windshields is a very common practice. Just keep in mind that it really isn't leaving all that much behind, so with heavy rain and the action of the windshield wipers, you may not see much of a long range benefit.
Originally posted by Jefri Lay View PostThanks again Murr1525, it seems that I'll continue using Rain-X. Just curious because some say that UQD can be applied on front glass too but now I now that it won't help much... thanks2017 Subaru WRX Premium - WR Blue
Originally posted by Murr1525 View PostWell, say I use RainX every 2 months. And the I wash the car every 2 weeks. So those weeks in between the glass would get UQD or UQW, kind of as a booster there also.
PS: I have attached some pictures on thread "How to restore my black color car?" and I will give some more when I finish detailing my car. So you'll now that everything work well or not.
Originally posted by Murr1525 View PostYeah, dont go crazy with the #84 till you do a test spot, look closely, follow it up with #80, etc and see the results.
