Bronco Fiberglass Top
  • Bronco Fiberglass Top
    I am trying to see if anyone can refer a product, I need to condition the the fiberglass top on a 93 Bronco we have. We used plastX but would like to see if Meguiars has something that has worked for someone on a textured surface.
    Re: Bronco Fiberglass Top
    The only thing I've found that helped mine is M07, Show Car Glaze. It's a pure polish full of oils. Clean the top well, then apply M07.
    Life isn't about 'weathering the storm', it's about learning to dance in the rain.
      Here's how it worked on mine.
      Found this beauty in a field last year, talked to the owner today and drove it home. She needs a little help. It will need a new paint job after the door repair, the hood needs it anyway. So I'm thinking, what better way to learn what's possible and how to use my new DA. I think this falls under EXTREME make-over, but it's not
        Did you ever get around to the marine line product on it?
          I was going to say RogueGypsy would be the person to ask, lol. Not much you can do with these things, it seems. I've tossed around the idea of getting the top sprayed with Line-X.
            I would think your best bet would be in the marine/rv line.
              They are made of fiberglass, but they have a weird, textured coating on them. It's sort of like textured walls in a house. Smooth, with some bumps all over. If you put dressing on, it'll run right off. You can't really treat it like regular paint either, IME, because it isn't...I think.
                Hmmmm, seeing that it is a '93 and has the textured surface has me thinkin' that it is NOT FG but may be ABS plastic.
                Around that time there were quit a few tops that were ABS. They were tougher (you could beat on them tough) than FG but a bear to clean. In some cases it involved removing the top and working on it with a scrub brush and cleaner with LOTs of water. As for a dressing for ABS, ain't got any idea.
                Good luck, keep us posted.
                Bill
                  I did try some of the marine line and if I recall #80 and #9. It's like Tyler said. It's not a smooth surface, it's like a texture spray. So any of the abrasive products I used started to smooth it out, reducing the texture. The oils in #7 were the only thing I've found that brings back the color without removing the texture. Same thing with Jeep and Blazer fiber glass hard tops.
