Super glue on paint... help!
  • Super glue on paint... help!
    My first DA project is getting more and more challenging.
    but it is a learning project so i will do whatever it takes to learn.
    even wet sanding.
    so...
    my wife's grandpa glue a side mirror back to the car...
    now it has some super glue on the side of the car...
    that i think would dmanage my new polishing pad.
    so i would like to use some sand paper to remove them...
    but i only have 1000grit 3M automotive sand paper...
    it is ok if i be really careful and remove just the glue?
    thanks,
    Steve
    sorry for all those questions.
    Re: Super glue on paint... help!
    even wet sanding.
    so...
    thanks,
    Steve
    First of all you may want to take a peek at the product's MSDS sheet and see if it suggests methods for removal. You may even want to phone 3M's product support.
      Acetone / Nail Polish Remover / Super Glue Debonder
      The Original Super Glue Corporation produces powerful adhesives for household/DIY projects, crafts, office and anywhere you need a solution that sticks!
      South Florida & Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
        http://www.supergluecorp.com/zap/zap-z-7-debonder
        These would be my first steps,before I started wet sanding.
          I really don't know how old that glue was...
          I might just skip that part, not to polish it so that i don't damage my pad.
          Can I get those in Europe?
          I am not in Kansas anymroe...
          and products are equal to that?
            How about trying a plastic scraper blade and some bug and tar remover to loosen it up first?
              Might be easier just to take a peek around instead of hoping someone knows if that stuff is available there. I'd have to imagine nail polish/acetone is. It's pretty universal stuff.
              Maybe I'm wrong, but I can see the possibility of chipping paint off in the process of trying to get the super glue off that way.
                Straight up..
                  i might as well try nail polish... haha
                  thanks
                    I use the plastic scraper blades all the time to remove badging and dealers branding stickers and have never once had a problem.
                      Am I missing something? Is the mirror on the exterior of the car?
                        Executionerhk,
                        If I understand correctly, you are planning to wet sand with 1000 grit and hope to remove the sanding marks with a DA Polisher? This process will require the use of a high speed rotary buffer as a DA Polisher will not do the job.
                        Brian Hann
                        Manager - Meguiar's Solutions Hub
                        Irvine, California
                        bhann@meguiars.com
                        (800) 854-8073 *3870
                          I do too. Bonded and cured super glue is a bit different than vinyl and emblem adhesive though.
                            You are correct: It chips off very easily unlike the sticky adhesives. I used a plastic scraper on about 10 drips of superglue that a neighbor of mine got on his BMW when he was trying to attach a fake M decal to his trunk lid, and it worked great.
                              I'm not saying it can't work. I was erring on the side of caution. What if paint does come off with it? Your going to be kicking yourself at that point. Do whatever you like though.
