hey guys today was the first time i used my PC and WOW i love that thing.. i did a day worth of work in 2hrs. anyways i used #81 and #26 paste and the results were good. not a big difference since my car is silver. i have some questions. i notice some light swirls under the light and was wondering would #80 fix it for sure? and what type of light should i use to see the scratches better like a reguluar 60watt light bulbs? and one last thing for the #26 i used a terry cloth to apply the wax onto my SONUS bluee pad is that okay??? or should i use a knife and spread it.
first time using PC
I'm glad to hear you liked using it a lot. I got mine a week and a half ago and have not had a chance to use it. I'm really hoping that I'll have some free time during the 3 day weekend to do a full detail and use my PC for the first time. We'll have to see how it goes...at least you were happy w/ itJason
2004 Jetta GLS 1.8T
Originally posted by travisdecpn
Florescent and Halogen lighting are probably the best ways to inspect your work. #80 should be enough to remove swirling, but it really depends on how bad it is. If #80 doesn't work you can use #83 which will most likely correct any swirling issue. Hope this helps.
Originally posted by jetta18T
I'm glad to hear you liked using it a lot. I got mine a week and a half ago and have not had a chance to use it. I'm really hoping that I'll have some free time during the 3 day weekend to do a full detail and use my PC for the first time. We'll have to see how it goes...at least you were happy w/ itj0hn
Hey,
Just to add....
xjdmb16a2six comment regarding the starting and the stopping of the PC is very important. Besides reducing/eliminating spatter, it also prevents the pads from flying off the backing plate. A pad that is saturated with product combined with the PC's action can cause a pad to fly off if the PC is lifted from the surface while still running.
How long does it usually take to become a film?Boss_429
Hey,
Just to add to Boss' reply,
When it comes to Meguiar's #83, or #80, you need to work the product until only a slight residue remains. Then remove with a MF towel. I have found that with a PC set to speed 5, a W-8006 Polishing Pad and #83, that it will take usually between 3-5 minutes for the product to break down over a 2'x2' area. Again, this depends on the humidity, temperature, and pressure applied to the buffer etc.... So your time may vary somewhat.
I hope this helps!
I found this thread very helpful.
Using #83 and #80, and getting your G100/PC to do the work of a rotary.
Hopefully the thread will answer your questions like it did mine.
Good luck
I used my PC for the first time today starting with #80. I did not see any difference really from start to finish in one certain area, so I decided to skip the step and move onto waxing. However, after reading Tim's post I think what I did wrong was I did not buff it enough. I guess I was just trying to stay on the safe side and avoid a dry buff. However, tomorrow I'll have to try it out again, and buff for a longer period of time to see how it goes and hopefully by then the results will be different. But the NXT wax still looked awesome!!Jason
2004 Jetta GLS 1.8T
