Re: How to achieve a flawless, mirror finish using Meguiar's M105 and a G110v2
Hi Macr, that makes complete sense. Are you applying M105 by a DA or a rotary polisher?
If you are using with a DA, then often times it best to judge the results you are getting as your polishing then looking for any film on the paint. Many times I have seen M105 continue to create amazing results while polishing across 'dry' paint, as long as the pad is still wet with product and has not become contaiminated.
The best judge is to polish to good light and inspect the finish as you work.
IF the product stops removing defects at the same rate, add a little more product and continue polishing (I would also clean the pad by brushing or blowing it out to be safe).
IF the product begins to leave micromarring, thoroughly clean out the pad. If cleaning doesn't work, switch to a fresh (but primed!) pad.
To give you an idea of the type of person Kevin is, he called me and asked if it would be okay if he added some information to my post: He didn't want to over step some boundaries as some people are sensitive to such (and understandably).
What Kevin fails to mention is that he is the master and I am the student, so THANK YOU Kevin for adding more information that is extremely relevant and for teaching us how to use this product with these machines better!
I 100% agree with your post. This why I always liked Mike Phillip's statement, "Find something YOU like and use it often." If you get excellent or better results with a particular product is isn't necessarily because product A is better then product B, it is because YOU are better with product A then product B.
Great post!
Thanks Joe!!!!
Originally posted by Marc08EX
View Post
Originally posted by Kevin Brown
View Post
Originally posted by Woodie6250
View Post
Great post!
Originally posted by Superior Shine
View Post
