Is this enough Ultimate Compound for 1 car? (picture included)
Re: Is this enough Ultimate Compound for 1 car? (picture included)
Likely a bit too aggressive of product for light swirl marks with a DA. You should order some M205. You'll like want to follow up with M205 on a black vehicle even if Ultimate Compound is needed.
You should be doing the test spot first with a less aggressive product like M205 it may be all you need.
Originally posted by Bandit Bill View PostLikely a bit too aggressive of product for light swirl marks with a DA. You should order some M205. You'll like want to follow up with M205 on a black vehicle even if Ultimate Compound is needed.
Originally posted by BlackHawk View PostAfter using Ultimate Compound would it be appropriate/acceptable to follow up with Swirl-X rather than M205?
Take a look at this link if you want to see how some products compare by aggressiveness.
The Aggressiveness Order of SMAT Products - This might surprise you! Super Micro Abrasive Technology = SMAT From left to right, the most aggressive to the least aggressive SMAT products From the most to the least aggressive... M105 Ultra-Cut Compound/M95 Speed Cut Compound = The same in abrading power
Originally posted by deep309 View Post
I like to make sure I've got more then enough to have to finish the job, and if that's all you have at the bottom of the tape my luck would be running out!
I'm interested in your outcome though!''USE THE LEAST AGGRESSIVE PRODUCT TO GET THE JOB DONE RIGHT''
Thanks for all the input. I will do a test area first but I will definitely look into getting some SwirlX and/or M205. When I looked at the aggressive comparison link it looks like the UC might be a bit too aggressive.
D.
Hey deep
Don't forget that pad-pressure-arm speed and speed on your DA also plays a role in how aggressive a product can be, you can take swirlX and with a more aggressive method be more aggressive then UC if your not using enough pressure-pad-speed you get the ideal.''USE THE LEAST AGGRESSIVE PRODUCT TO GET THE JOB DONE RIGHT''
This may be comparing apples to oranges, but I have a 2009 Town and Country with minor swirls, swirls so minor, than Gold Glass liquid fills it in and hides them very well. Anyway, I tried Swirl X with a green CCS pad with my PC on 6 and it did not do a lot to correct the swirls. I have some UC left over form my father-in-law's Dakota and I have yet to use it on the Town and Country. Even on that Dakota UC with a yellow CCS pad did no better than 80% correction on two applications. I am under the impression that Chrysler jsut has some really hard paint.
