Alright, so I have been reading quite a bit and would like discuss some personal conflicts I am having between the pro and consumer lines.
If I am reading correctly, it seems that when comparing like products from the consumer to pro lines, the primary difference is that the pro line is suited for a rotary (feel free to correct this statement).
Here's my issue...
I have personally never used any of the Pro products but, even though I use a DA, I find myself really wanting to try the Pro products. Maybe it is just years of being conditioned by marketing, but I can't help shake the feeling that I am leaving something on the table with the consumer products. Plus it is just down right cooler to refer to products like M07, M21 & M26 than it is a descriptive name.
So, what I really need is for someone to tell me (1) "K3ith, your being stupid. The matching consumer products will give you as good of a result as the pro products if you aren't using a rotary". OR (2) "k3ith, actually your reading is a bit off and even if you aren't using a rotary, the matching pro products will give you a better result". OR (3) "k3ith, since the pro line is suited for a rotary and you don't use one, the consumer line is actually better for you.
Of course, I understand the answers might not be that simple. If not, we can take this as a discussion on "Comparing the Like Consumer Products with Professional Products when not using a Rotary".
Thanks in Advance.
Here's my issue...
Thanks in Advance.
