Rain X Windshield ??
  • Tim Lingor
    replied
    Re: Rain X Windshield ??
    Originally posted by 3Fitty View Post
    Hey Tim.
    I've been using UQW on my windshield and I just started getting chatter, any thoughts? I've never used RainX on the IS (have on the CR-V - with no chatter) but I'm a bit ticked at getting chatter on a virtually new wiper blade on the IS.
    Hey 3fitty, it has been a while my friend!
    Because UQW was not designed for windshields, I would imagine that when the product wears off, just like when RainX does, it will provide places where the wipers grab and others where the product remains, glides right over. Hence, severe chatter in some cases.
    Honestly, I am not a fan of waxing a windshield as a wax normally will cause smearing and star-bursts when a headlight shines through it at night. I normally use M04 Heavy Cut Cleaner to clean the glass thoroughly and then maintain with Meguiar's Glass Cleaner.
  • 3Fitty
    replied
    Originally posted by Tim Lingor View Post
    Exactly! I will not use it for that very reason.
    Instead, what I do use and really like is the RainX Windshield Washer fluid. It leaves a nice coating that does not smear and it does not cause the wipers to chatter.
    Hey Tim.
  • tcy006
    replied
    I have used it for years on several vehicles and never had a problem with blade chatter. I agree with Greg that small drops do not blow off and require the wipers, especially the spray from other vehicles. I think they changed the formula from years ago, it doesn't last as long as it once did. I am going to have to try AquaPel, I never heard of it until today.
  • Tim Lingor
    replied
    Originally posted by roushstage2 View Post
    I never use it anymore. Tired of the chatter it causes on all of my cars. I have an Aquapel application waiting to go on the Neon when it starts raining.
  • Blueline
    replied
    Same here. The blade chatter was terrible.
  • G_S_DB
    replied
    One aspect of Rain-X bothers me...
    Big rain drops easily slide right up and over your windshield, but sometimes big rain drops hit your windshield and burst into thousands of little drops. Those little drops don't always catch enough wind and require you to hit the wipers. Some of this could also be dependent on the rake of your windshield, but that is just a guess. Other than that, no problems.
  • CieraSL
    replied
    Originally posted by nsmokey View Post
    I will use the advice. I am not tuned yet on the different abrev's don't know what UQW is.
    Smokey
    UQW is short for Ultimate Quik Wax. You might find this handy: Meguiars Online Acronyms
  • nsmokey
    replied
    Thank all of you for the info. I will use the advice. I am not tuned yet on the different abrev's don't know what UQW is.
    Smokey
  • wwally
    replied
    I have used both the Rain-X and the AquaPel. I think the AP is a much better product--It lasts for months, gives good beading of water and makes the wipers silent on the glass. I thought the Rain-X worked only half as well and made a big mess.
  • Murr1525
    replied
    Originally posted by james0509 View Post
    the instructions only said "do not over apply"
    And there really isn't a way to know what is over applying and what isn't.
    No way to judge unless you actually DO over apply.
    Just teasing of course...
    If you use a damp/moist MF cloth, followed with a dry one, most of the problems should go away.
  • roushstage2
    replied
  • Megafast13
    replied
    Ultimate Quik Wax is by far better. RainX is alcohol based, smells bad, VERY hard to remove, ruins towels, etc. Definitely use UQW, it works better and is easier to apply... Just Spray on window, wipe off. You don't have to buff and wipe over and over to try to get a clear window.
  • james0509
    replied
    This comes back to "dont follow the directions.."
  • CieraSL
    replied
    Rain-X is a great product. Only gripe I had was durability. Other than that, nothing wrong with it.
  • Murr1525
    replied
    I used a bit too much and it took a while buffing the window clean
