I've finally decided!!! BUT WHICH ONE?!
  • #16
    Re: I've finally decided!!! BUT WHICH ONE?!
    Note that the AMG above what mainy corrected with a white pad...
    On topic, I would recommend staying with a flat pad design when using M105/M205 as the CCS design can reduce the surface area (and thus the abrasives in contact) with the paint. You will get a better cut with a flat pad, IME.
    • #17
      Nice work on those cars Todd.
      And yes, I was making a melodramatic statement. I wasn't trying to be bold.
      • #18
        I understand that this thread might be going in different directions, but hey, just let us discuss . (to the Mods who constantly say "Hey go to this thread, or use the search function, or create a new thread...but when we do those things, they get angry at us for reviving an old relevant thread, or they get mad at us for creating a new thread etc. Catch-22 and they just like to yell at us; phew that felt good.)
        Mr. Bella Machina, maybe you could offer your opinion some more .
        Would you say the consensus is that if one intends to have success on a variety of cars with his "normal" DA like the G110/7424, he should be using LC pads?
        Because out of the last 5 cars that I did (99BMW, 97Ford, 03Honda, 07Maserati, 09Honda) w/my G110, Meguiars Pads +m105&m205...the new Honda was the only car where I achieved any appreciable level correction, really.
        I've been considering the Flex for a while (because I've been disappointed w/ the G110 (or maybe it's the SoftBuff 2.0 yellow pads that I use...!?), but I'm giving the G110 a second shot. Hence, my recent purchase of 2 5.5'' LC oranges, and one white.
        What's your take? Notice how I use the flat, SB 2.0 yellow pads, and have little success.
        • #19
          So the topic has strayed a bit....... it's a good discussion with great information. Carry on boys, carry on.
          • #20
            That is a bold statement... I have removed plenty of swirl marks with a LC white pad, with both a rotary, a flex, and a dual action polisher. I also work on a lot of Ferriar's which feature the PPG Cermaclear paint as well.
            Perhaps a better way to phrase that statement is that you cannot get swirl correction from white pads...
            WOW! Do you actually get paid to work on these cars?
            Magnificent work! Hey, I'm just around the corner if you ever need a delivery driver!! I can hardly see the wet sanding marks at all!
            "If we knew what we were doing, it wouldn't be called research would it? (Albert Einstein 1879-1955)
            BOB
            • #21
              wow I'm learning a lot just by reading the comments.. .even though I didn't intend to open up this informative discussion
              • #22
                Thanks. Yes I am very lucky to have an excepitional client base that allows me to push my limits as a detailer.
                I have done a lot of exotics, super cars, but nothing comes close to the privledge of working on this car...
                • #23
                  Uhhh....
                  These rank very high on the "!OH!MY!GOSH!HOLY!SMOKIES!" list.
                  Kevin Brown
                  NXTti Instructor, Meguiar's/Ford SEMA Team, Meguiar's Distributor/Retailer
                  • #24
                    WOW!! those are astonishing pictures...
                    Ganesa,
                    Toyota Vios '05
                    • #25
                      How's the backing plate work with those pads? I'm hoping someday Meguiar's will include the proper backing plate as they deplete their old backing plate inventory.
                      I recently started using the new bigger backing plate with my G110 while buffing my motorhome. Works great with the Megs pads! With the original plate, I had to realign the pad after cleaning on the fly and often while just buffing. Not one realignment was needed while doing a 37 ft. motorhome!
                      Barry
                      • #26
                        I've used my G110 + M105/M205 combination on very hard Audi paint to acheive a 90% correction and I'm sure if I had the skills of Kevin or Todd, i could have achieved 100%. I think technique and time play a big role in what you can achieve with a G110 or PC for that matter.
                        I found that originally, I was working the DA way too fast (almost like a rotary) and it didn't give the polishes an opportunity to work on a particular area long enough. It was almost as though I was spreading the product around the paint, instead of correcting.
                        Once I started slowing down and applying more pressure, my results improved dramatically.
                        • #27
                          Asking for my advice is the fastest way to get me in trouble....
                          I don't think you have to exclusively lock into one brand or can say one brand is better then the other. There are times when for whatever reason, a particular brand, or a more specific style of pad may better fit your needs.
                          Meguiar's pads, particularly the So1o and SoftBuff 2.0 pads have many desirable design features. The backing plate mounting is recessed, which prevents the backing plate or Velcro material from damaging the paint and center's the plate to the pad. The edges of the pad are rounded or beveled, so the prevent the creation of pressure spots that can stall the rotation of the pad or create marring, particularly on a rotary buffer.
                          And they use very high quality foams: The 7207 foam is really amazing, capable of removing defects will little to know surface scouring.
                          Lake Country is a dedicated pad manufacturer, so they have some distinct advantages over Meguiar's. They come in a variety of smaller (and larger) sizes; most people find that smaller diameter pads work better for them on a Dual Action Polisher.
                          But they have a big down fall: Lake Country makes their pads to their customers design specifications, so all Lake Country pads are not created equal. Ordering a pad for them is likely checking an order sheet at a car dealership...
                          Do you want rounded edges? Do you want the backing material to be back cut or do you want it to run across the entire back of the pad? Do you want the backing area raised, flat, or recessed. As you add on desirable options the pads become more expensive to make, purchase, then sell. If you look at some of the vendors that sell their version of Lake Country pads you will notice that some vendors sell pads that feature no options and other vendors have highly optioned pads. This creates confusion in the market that Meguiar's doesn't have worry about. All Meguiar's pads are created equally and have the highest quality features.
                          So as a whole you always know the quality you get with Meguiar's pads, with Lake Country you are more at the mercy of the vendor.
                          The main problem is going to be using a 7 inch pad on a random orbital polisher, as the size (and friction) caused by the pad can bog the motor down. The larger size of the pad makes it less efficient then a smaller pad as it absorbs more of the orbital motion of the machine.
                          I think if you tweak your technique with a 7 inch pad you can get it to work (and work well) with a Dual Action polisher however. Remember you asked for my advice, so here goes...
                          You need to use more pressure with a larger diameter pad. Because the size of the pad means that it is less efficient at transferring the motion of the machine to the paint (the pad absorbs it) the pad needs to be compressed further.
                          Keep in mind that a larger pad will spin slower anyways (because of the increased contact area of the pad on the paint) and adding more pressure will slow that reduced rotation even more. This is the trade off of using a larger pad, you have to add pressure to make the foam more efficient, but you do loose the rotational speed of the pad.
                          You do not want the pad to stop rotating completely, but use enough firm pressure to keep it turning at a steady pace.
                          Use the largest backing plate you can fit on the pad to make sure the pressure is evenly distributed over the pad. If you are using a pad that doesn't have rounded edges you may want to use a smaller backing plate to keep the edge of the pad from digging into the paint.
                          Use speed 6, with firm pressure, and slow movement. If you notice the pad begin to stall (stop rotating) then ease up just a bit and continue moving.
                          Before jumping to new pads (which may very well work with your techinque) I would try adding more pressure to your current technique. Most people will use light pressure (to get more rotation) with a 7 inch pad, and while this looks good in theory, it actually is counter productive because of the design of the pad.
                          Focus on working a small area, 18 x 18 inch's, with firm pressure, and slow over lapping passes.
                          The reason I say you might need a little adjustment to your techinque is that I have gotten very good correction using SoftBuff 2.0 pads on a Dual-Action polisher and so far countless others. It might just be a small tweak is needed to dial in the feel of that system.
                          The forced rotation of the Flex and the awesome foam of the 7207 makes it an absolute defect killer that leaves the in great shape afterwords. The Flex has enough power that the 7 inch pad becomes an advantage, all though with the right technique on a Random Orbital, it shouldn't be a disadvantage.
                          I would give the 7207 pad a shot personally on the DA first. The firmer foam should require less pressure to compress and should spin fine on the G110, as well as give you the power to remove defects effectively. Firm pressure and slow movements.
