G110 on its way to my house......few questions.
  • G110 on its way to my house......few questions.
    OK, mainly, what i need to know is what speeds to work which products in with and for how long.
    2 step (Compound 1, LSP)
    3 step (Compound 1, Compound 2 , LSP)
    Thanks guys!
    Zach Hall
    Re: G110 on its way to my house......few questions.
    Most of us work compounds and cleaner/polishes at speed 5 and apply LSP at speed 2-3. Working time for compounds will depend on what the compound is, type of paint and how bad your defects are. Best to do a test spot. Here is a good write-up for #80 by Mike Phillips.
    How many passes to break the diminishing abrasives in M80 down? (http://meguiarsonline.com/forums/showthread.php?p=192688) I am going to use #80 on a polishing pad.. How do you know when the diminishing abrasives have broken down? Also how many full-size sedans can you buff out using a single 32oz bottle of M80?
    Black......the ONLY color!
      Thanks guys!
      In addition to the great info found in the thread mentioned above on direction / pressure, here are some good guidelines for speed...
      Paint cleaners / compounds / swirl removers 3 - 5 on the speed dial...
      LSP's 1 - 3 on the speed dial
      We also added a decal on top of the machine with these same suggestions
      Mike Pennington
      Meguiar's, Inc.
      800-854-8073
      mpennington@meguiars.com
        oh ok good!!!!!!
        Zach Hall
          so if i was to use like......#7 SCG would that be a 1-3 or 3-5 product
          Zach Hall
            M07 is a pure polish containing no abrasives, thus you do not need to forcefully spread it over the paint over and over to be effective. It simply needs to be evenly spread across the surface once, and then removed.
            Just think of it this way, anything that needs to be forced against the paint to try and remove actual paint (compounds and abrasive polishes) will need speeds 3 and above, and anything that is simply being spread over the surface (Pure polish like M07, waxes) can be done with speeds up to 3.
            Make sense?
              excellent answer...thanks buddy!
              Zach Hall
