Using the yellow foam applicator pads what is the best technique to apply ultimate compound and swirl X? Do you use a side to side or circular motion? Also how much do you apply at a time? A circle around the outside? An X? ect. If you have a video of you applying these two products or just one of them that would be awesome!
Technique
Re: Technique
you want to work small areas, like the size of a microfiber. If your goal is to remove swirls, then either side to side or circular motions work fine, also work the product in for about a minute and then wipe off the residue with a clean microfiber and inspect your results. If you like what you see, do the next section, if not repeat with SwirlX again and if that dosent work then try UC.Nick
Re: Technique
Originally posted by Hoffer View PostAlso how much do you apply at a time? A circle around the outside? An X? ect. !
after you work a couple sections your pad will get saturated with product, When I use SwirlX i like to wipe excess product built up in the pad with a clean cotton towel. It works for me because I know I dont have too much product built up in the foam applicator pad.
is your goal to remove swirls or just looking for a good paint cleaner/polish?Nick
