Deep Crystal cleaner and ScratchX 2.0 question
  • Deep Crystal cleaner and ScratchX 2.0 question
    My next detail I am going to use both these products, using the cleaner on the whole car and the scratchX on the bigger scratches. Which one should I use first?
    Richard
    Re: Deep Crystal cleaner and ScratchX 2.0 question
    Scratch X.
    But you may need something more aggressive like Swirl X or Ultimate Compound
      Yeah, hopefully you picked up the ScratchX 2.0 at least?
        Yes, I picked up 2.0. What happens if you use a product that is to powerful?
        Richard
          Do you mean one that is more aggressive than you need?
          If so, that just means you will be doing more work than you need too, and spending more time and money.
          But it should not really damage anything.
          I hope the detail is going well!!
          Good Luck!!
            The ScratchX 2.0 is not "super strong" to where it would dig through your paint if you used it.
            Using a strong compound by rotary buffer, or wet sanding, is certainly the extreme.
            Just use he ScratchX 2.0 on your bad spots, see how it works, get your techinique right. Ask back here, and with pics, if you have any problems/questions. Make sure it all works in one spot before you do the whole car.
              Always do a test spot on to get a process dialed in. As Joel said, if you use a too harsh product then you will have to go down a step to clean up what that did.
              Test spot will dial in a process.
              Watcha working on?
              Do you have a machine or by hand?
              Keep us posted!
