#80 Question
  • #80 Question
    I am planning to do my annual winter details on my two black Acura's - 06 MDX and 07 TL - both with moderate swirls and scratches.
    MDX
    TL
    I just purchased a G110. My plan is:
    1. Gold Class wash
    2. Clay
    3. #80 with 8006
    4. NXT 2.0 with 9006
    I will do a small test area first, but was wondering...if the #80 is a bit too aggressive (read several posts about concerns with marring and "soft" Acura paint) what would be the next less aggressive cleaner/polish to try with a DA - #9?
    Thanks.
    2013 Highlander - black
    2010 TL - black
    Re: #80 Question
    hiya, i would say #82 then #9 would be steps down from #80, it is always advisable to use the least agressive combination, so you could try #80 with a finishing pad before the above, if you have #80 and polishing and finishing pads they should take care of the swirls
      Re: #80 Question
      christian6984 - thanks for the help.
      2010 TL - black
        Re: #80 Question
        You could also try something really simple and that's to use ColorX with either a polising pad or maybe even a finishing pad.
        ColorX is a one-step cleaner/wax that does contain diminising abrasives and if your paint is soft and the swirls are light then it might just do the trick to remove them while leaving the paint protected when you're done.
          Re: #80 Question
          Good idea. I have a bottle of ColorX and didn't think to go that route. Thanks, Mike.
          2010 TL - black
            Re: #80 Question
            This works very well on my TSX.
            W9006 + ColorX or M66
            Rasky's Auto Detailing
              Re: #80 Question
              I was thinking along the lines of #66, also. It is one of my favorites as most of you know. :
              Last edited by J. A. Michaels; Oct 20, 2008, 10:24 AM. Reason: Wrong smiley picked.
                Re: #80 Question
                Thanks, RaskyR1.
                Do you find you TSX paint to be somewhat soft? What color/model year?
                2010 TL - black
                  Re: #80 Question
                  Originally posted by gjohn28 View Post
                  Thanks, RaskyR1.
                  Yes, VERY!
                  2008 Milano Red...it has the tinted clear too. I was getting very frustrated with it and then Mike tipped me off on using ColorX/M66 with the Finishing pad.
                  Now I pretty much use that once a month and then NXT 2.0 every other wash.
                  My girl has a 2005 Acura RL in the same NHPB color as yours. Her paint was in far worse condition than yours. I went over it with M80 on the rotary followed by M66 on the FLEX and it turned out great.
                  Rasky
                    Re: #80 Question
                    Here is her RL
                    My girl picked up a 2005 RL last night and I thought I'd give it a quick once over. M80 with W8207 on rotary M66 with W8207 on FLEX Before 50/50 After Thanks for looking
                      Re: #80 Question
                      Thanks.
                      Is #66 more aggressive than ColorX?
                      2010 TL - black
                        Re: #80 Question
                        Great RL pics - great detailing job! Beautiful car, too. (I am an avid Acura fan and plan on rolling into an RDX when my MDX lease expires this spring.)
                        You mentioned in your previous post that you got frustrated doing the TSX. Was that because of the soft paint and marring issue or something else? Were you using #80?
                        BTW, sorry, but I don't know what "NHPB" means?
                        2010 TL - black
                          Re: #80 Question
                          Thanks.
                          Yes, it's a tick more aggressive.
                            Re: #80 Question
                            I've had the absolute best results with my PC using scratch-X, and this is on two black cars that #80 tends to turn a bit hazy no matter which way you work it. The scratch X has much more corrective power then #9 and color-X, yet always finishes off with a crystal clear haze free finish
                              Re: #80 Question
                              OhioCarBuff is right, we often forget about how nice ScratchX finishes out.
