removing 3M tape residual
  • removing 3M tape residual
    need some suggestions please:
    on how to remove the residual glue (from 3m dbl stick tape) on a painted surface
    thnx!
    Re: removing 3M tape residual
    Just about any paint care product if gently applied and worked into the residue and loosen it so you can wipe if off.
    ScratchX
    Deep Crystal Paint Cleaner
    Cleaner/Wax
    What you don't want to do is rub hard with anything and possibly instill scratches from rubbing to hard.
    Goo Gone or Goof-Off will work also and can be found at most stores.
      Heat it up with a hair dryer or heat gun (careful with the heat gun though as some can get really hot) then use some Goo-Gone and work it in good. It will take some time but it will come off. Remember to wax the area when you're done!
        thanks for the suggestions..!
        i have tried the goo-gone, it took some of the glue residue off, but i still have some left.
        i then tried meguiar's clay and that removed some more
        followed by meguiar's cleaner/wax
        still got some left....
        so, next would be the heated solution or scratch X or deep cyrstal paint cleaner and just slowly working the products you all mentioned.
          ive got residue on my unpainted black trim (roof mouldings) that i havent been able to get off for months. tried 303, DC1 and gold class trim detailer. going to try turps or goo-remover next, nothing seems to be working!
            is this a byproduct of taping off the vehicle to polish/wax?
              no... it's leftover 3m tape/glue residual when i remove my spoilers
                i was referring to the residue from taping. not caked-on product against the edge of the tape but actual sticky residue from the tape itself, caused by being left on too long in too hot weather.
