What do I do to remove this?? AHH!
  • What do I do to remove this?? AHH!
    my first scratch!!!...what should i use to remove this?...it is not that deep..
    dont know if someone tried to key the car..
    thank you all!!!
    Re: What do I do to remove this?? AHH!
    i am only working by hand...debating on whether i should use scratch X?...i just waxed car on saturday..can someone help me as to what i should do?...remove wax in that portion before using anything else?..etc..
    when i first noticed it yesterday...i used cleaner wax..it did help a little bit..but i dont know if that was "stupid" for me to do..
    thanks!
      hi there,
      first
      wash
      clay
      Scratch-X
      it might take a couple of passes of scratch-x but that should do the trick. follow it up with #7 and than a coat of NXT (see below).
      use a foam applicator pad, and apply plenty of passion (elbow grease)
      make a few passes and then wipe of the product and see if its up to your standards. if not, repeat the application.
      work in the small area and go in a few different dirrections.
      let us know how it goes...
      wash
      clay
      scratch-x
      #7
      NXT x 2
        It looks pretty light. I'm sure ScratchX would help out quite a bit.
        Truffle and I posted at the same time, but he is totally correct.
        Chris
        Dasher Detailing Services
          Looks like a really easy fix. Just get some Scratch-X and rub that sucker out. Read through the Forums and you will find articles about how to remove scratches via Scratch-X. Here is one link:
          How to Remove Defects Using Scratch-X
            honestly from the pic i was thinking it was paint transfer.
            the last one i did (paint transfer) it took me 3 passes and 35 minutes and it was ALL GONE!!!
              I would suggest starting here... How to remove a defect by hand with ScratchX
              Edit: Ya, what they all said. I'm slow today, I have a cold.
              Scott
                Using a paint cleaner was the right idea. Just need a stronger one than the cleaner/wax. ScratchX should do fine.
                You'll of course want to go back over that area with your cleaner/wax, or a polish and wax, etc.
                  Originally posted by TrufflePig
                  oh yeah its pretty pimpin' if you polish your car in a suit and tie
                  i like the professionalism.
                  HAHAHAHAHA (just got off work)...i will wash, clay, etc next weekend..and purchase scratch x...appreciate the replies everyone..
                    The scratchx should do the trick. Remember it takes a little "passion" to do the trick. Let us know how it works.
                      BTW, Passion=Hold your breath, grit your teeth and drive you heart rate up to about 225 beats per minute.
