Paint Thickness Guage
  • Paint Thickness Guage
    Im looking for a cheap guage that works. Im thinking about this one.
    eBay Item #150106909421
    2005 Toyota Camry LE Phantom Grey Pearl
    2001 Toyota Corolla LE Silverstream Opalescent
    1996 Lexus ES300 Ruby Pearl
    Re: Paint Thickness Guage
    Did you ever get this gauge and use it? If so how did it work out?
      Do you need one for using a DA?
      How do you tell if the paint is single stage?
        No
        Using any type of abrasive product (polish or compound, even a strong cleaner wax) should result in paint transfer to your pad or towels.
          Is there anything you need to do differently when working on Single Stage Paint?
          BTW Thanks a lot Mark!!
            Not really, just realize that it will look a little different as you work on it since you are working directly on the color itself, instead of trying to polish a clear paint above the color.
            Also, the pigment that determines the paint color will sometimes effect how hard the paint is. Generally, white is the hardest and black is one of the softer colors.
              Thanks Mark!!
