I have a 2006 red VW GTI and while it shines, I would like it to POP! The pictures from the "Pre-Holiday Fun Class!" shows off a trunk lid Miata where you "could scan the barcode in the overhead fluorescent lights!" I would like my GTI to look that way but sanding my scares me. Is there combination of products that will get me close or is sanding the only way?
Let’s assume that I sand, did you sand through the clear coat into the base coat or is the orange peal mostly in the clear coat, and then how do you keep that way after you’re done?
My GTI has a sealant and tow coats of NXT on top of the clear coat so if I elect not to sand what would be your recommendation for products to remove as much of the orange peal as I can and still keep my clear coat intact?
What I want to eliminate or reduce as mush as I can
