Wax on rubber and plastic
I got a 'lil sloppy and got wax on some rubber and some textured plastic. I have tried many different products, including 'back to black'. It still looks terrible, does anybody have any suggestions? thanks
Shine on, Shine on, harvest moon...
ok I dont sing for squat!
2002 Chrysler Pt Cruiser Dream ser 1Tags: None
I have a couple suggestions that may work. First, I recommend that you use our # 39 Heavy Duty Vinyl Cleaner, along with a small brush (tooth brush type). Spray the M39 directly onto the brush, work the brush thoroughly into the areas where the wax residue is lodged. May require a couple applications. After this application, apply a product like our Trim Detailer (G10810). Wipe off any access product.
Be careful not to allow any of the M39 to dry on the paint while working on the trim, wipe off excess with a moist towel. Depending on how long the wax has been on the surface and the type of plastic will determine how well this works to resolve it. These two products have done very well in past situations like this.
Good luck,
Tom
Originally posted by Tom MacDonald
Boy and I thought creamy p-butter was just good on pizza. Please explain exactly what you were using it for on your Mini.
My daddy used to say dont knock it if ya havent tried it!Shine on, Shine on, harvest moon...
#39 and a toothbrush worked for me in the past. Also, 3M Tire Dressing also effectively removed excess wax in black plastics.
To prevent getting wax or sealant on black plastic, I mask those areas off with 3M Blue Painter's Tape, which is available at any hardware or paint store. Masking off the black areas before you wax will save you a TON of work!
Your dad was wise about "try it first!!" Peanut butter pizza has pizza crust, tomato sauce and the peanut butter on top, cooked. Ate it on a dare at Hell's Kitchen in LA and it was AMAZING. We ordered two more!!
As for the trim pieces. The important thing about removing is to clean well first with the brush before applying anything on top.
~Tom
~Tom
BTW I would not recommend using Bacon lettuce or tomato to remove wax residue on your plastic car parts.Got Faith?
Popular pizzas here are Chicken wing (duh, it's Buffalo...we have chicken wing cereal for breakfast!and Mashed Potato pizza...tastes like a loaded potato skin....
Bill Poirier
West Seneca, NY 14224
