Removing wax prior to using G100
  • Removing wax prior to using G100
    Here is the story:
    I have a 2004 Nissan Titan (my business vehicle). I have taken great care of it - but there are some minor swirls here and there - and I want to use the G100 on my own vehicle before I try on somebody elses.
    The last time I detailed it, it was a basic clay bar/DC#2/NXT Tech wax (x2).
    My question is what can I do to "strip" the wax that's on there before I use #83 with the G100? Do I need to do this, or can I just go to work with the #83?
    Thanks in advance...
    Nate Williams
    N.E.W.car Mobile Detailing
    You dont need to remove any wax. Just give a good wash, then check to see if you need to clay at all again. If so, then clay, if not, then go on to the #80/#83.
      Thanks.
      It doesn't need clay - it was clayed about a month ago. So I should be good to go after a good wash...
      Nate Williams
        The M83 Dual Action Cleaner Polish is a Paint Cleaner so it will remove minor to moderate insurface defects while remove any old wax on the finish at the same time.
          How can you tell if there is old wax on the car?
            How to determine the presence of wax:
            The Squeak Test - How to test for the presence of wax (http://meguiarsonline.com/forums/showthread.php?s=&threadid=6825) This article can be found in the Meguiar's How-To Articles (http://meguiarsonline.com/forums/forumdisplay.php?s=&forumid=33) forum ~~~~~~~~~~~ An accurate indicator of whether there is a
