Need something stronger than ScratchX?
  • Need something stronger than ScratchX?
    My car has some pretty heavy swirling. The previous owner used to clean the car by wiping it down with a wet chamois. Its not hard to imagine how all the trapped dirt in the chamois swirled the car in a big way over the past few years!
    Anyways I gave ScratchX a go on the paintwork. It removed about 70% of the (lighter) swirls but it cant seem to reach the deeper ones, even with multiple applications and 'passion' with a terry towel. These scratches are definitely still in the clear coat, not the base. So the question is, now what?
    I was thinking of trying Meg's Fine Cut Cleaner or Swirl Remover 2.0. Would that work better? Unfortunately products like DACP is not available here.
    Unforunately PCs and the like are really expensive out here Down Under so I'd like to stick to Hand Application if at all possible.
    Thanks in advance.
    Leo
    Hey Leo,
    welcome to megs online!
    Check this out before you use something else.
    How to use ScratchX by hand to remove swirls, scratches and water spot etchings (http://meguiarsonline.com/forums/showthread.php?t=1516) How to use ScratchX by hand to remove defects like these, Scratches Swirls Bird Dropping Etchings Water spots Scuff and Mars + + = Success! A couple of important notes to
    Andy
    101impala
    Andy M. Moderator
      Thanks for the link. I pretty much followed that proceedure that Mike had put up. I think maybe I need something stronger than ScratchX? DACP isnt available here unfortunately.
        i would say go over the area again with scratchX, its not uncommon to do use scratchX several times
        Patrick Yu
        2003 Honda Accord
        2008 Honda Accord EX-L V6
          I think that Scratch X is the best you can do by hand, you can try #80 or #9 by hand but I don't think it'll remove swirls as good as scratch x w/out a PC
            Thanks guys.
            I've used Scratch X as Mike has suggested, repeating the application 3-4 times. Going by what people say here, nothings better than Scratch X by hand (including #1) , so PC is the only answer now?
            I thought #80 and #9 were PC only products?
              Speed Glaze
              Enriches gloss and color with machine or hand application. No matter how you choose to apply it, Meguiar’s Speed Glaze is a shortcut that cleans, polishes and protects in one simple step. You will quickly remove light scratches, stains and environmental contaminants. Speed Glaze is safe and effective on any kind of paint finish, including clear coats. It ensures that a deep, beautiful shine is just minutes away. Made for professionals.
              Swirl Remover
              A cleaner and a polish in one bottle. If, much to your dismay, you notice swirl marks, tiny scratches or other mild defects, you'll appreciate our ultra-safe Swirl Remover. This amazing product will carefully eliminate those annoying problems-whether applied by hand, or using a machine buffer/polisher. While Swirl Remover is gently cleaning, it's also polishing, leaving a dramatic, high-gloss shine. It's even formulated to reduce splatter and make application and wipe-down easier. For use by hand, orbital buffer, dual action polisher or rotary buffer. Made for professionals.
