Originally posted by Murr1525 I think it is the best product out there for daily drivers if you are short on time.
it has a little more bite than the cleaner wax and i was so impressed with it (used it with the pc), i just bought another bottle (had a little less than half a bottle left). this is definitely a sleeper product...
I did use Speed 5 with the colorX on a w8006 pad. At speed 5, I could really tell the difference it made as it worked in the diminishing abraisives. My client said he was now proud to drive his Acura again. Hopefully, he'll give me some repeat business over the spring. His finish could use a claying and some more cleaning.
Proud owner of the finest looking car in the parking lot.
Switch to Linux. Use energy efficient lightbulbs and appliances. Keep your car well maintained and drive easy to save gas. Eat less fast food. Call your mother and tell her you love her. Try flying a kite. Read a wikipedia article daily. Use Meguiar's.
Originally posted by LiquidBlack I did use Speed 5 with the colorX on a w8006 pad. At speed 5, I could really tell the difference it made as it worked in the diminishing abraisives. My client said he was now proud to drive his Acura again. Hopefully, he'll give me some repeat business over the spring. His finish could use a claying and some more cleaning.
Thanks for the answer...can't wait to try it on my car in Spring....have a great weekend....
Bill Poirier
West Seneca, NY 14224
Hey,
I am glad everything worked out!!!
As I said earlier in the thread, ColorX works very well when used as a cleaner with the PC set to speed 5. It allows the diminishing abrasives to break down properly, leaving a deep, rich finish!
Since ColorX is a strong cleaner with diminishing abrasives, is there a limit how often it should be used? Could ColorX be used as your LSP and applied every six to eight weeks?
Just to clarify...ColorX is not very aggressive compared to a true compound/cleaner product. If you compare ColorX to a cleaner wax all-in-one product, then yes, it is a little more aggressive. So, in other words, I would not be afraid to use ColorX once a month.
For the sake of conversation would it be a safe assumption that #66 would be a stronger cleaner wax compared to Color X when used with a PC and 8006 pad?
Originally posted by George Wax For the sake of conversation would it be a safe assumption that #66 would be a stronger cleaner wax compared to Color X when used with a PC and 8006 pad?
Originally posted by George Wax Thank's for the quick response..would it also be safe to say #66 would be a stronger cleaner than Speed Glaze? When used with a PC and W-8006?
Hi George,
That is a tougher comparison as they are very similar in cut, but I have found that M80 will work a little better with the PC when compared to #66. With the rotary, the results are very similar. The M80 tends to leave a deeper, more rich looking finish. M66 tends to leave a brighter, more clear looking finish. It all depends on the look you are after.
I like using M66 with the rotary, topped with #20 Polymer Sealant. This combo gives a crisp, clear look on lighter colors!
But, one of my personal favorite combos is M80 with the rotary, #82 with the PC, topped with #21. This combo looks awesome on darker colors!!
