Re: 1976 Silverline Deville Boat - Extreme Makeover
In the past what I've done is to only load the boat partially onto the trailer, then secure it really well then pull it carefully out of the water and then worked on the sections not normally reachable when the boat is all the way on the trailer. You have to be very careful when you do this and you have to use good judgment on balance.
Another way is to cut the side guides off and then re-weld them on after the buff-out is finished.
With my last drag boat, I removed the engine and all running gear and then invited a half a dozen friends over and lifted the boat off the trailer and set it down on some Semi Truck Tires. After doing the sides, then turn the boat upside down on the tires and get the bottom. While the hull is off it's also a great time to replace the runners on the trailer and do any trailer maintenance.
A lot of work but only had to do it a few times in the 20 years I owned the boat...
Originally posted by Mr Mustang
View Post
