Rock Chip Repair
  • Rock Chip Repair
    Hi:
    Well, looks like I am going to try to repair a rock chip. At least I am considering doing it but have never done this before. In the past I would just fill a chipped spot with paint and stop; this time I would like to level the repair and blend it with the paint so it will not be noticeable.
    I plan on following the procedure I found on the Better Car Care web site.
    The chip is in black paint and about 1/16" diameter. As you would expect the chip exposes the bare metal. All the paint around the chip is tight.
    Any suggestions or tips on how to do this would be appreciated.
    Leveling the paint after applying it is the part that I need help with.
    Since it a small area should I use a sanding block or sanding paper?
    What grit should I use?
    How big an area around the chip do I need to work?
    Regards,
    KTruck
    Make it Shine
    I have not tried it personally, but a friend of mine told me about a product called Langka which advertises itself as the "blob eliminator." What it does is soften the touch-up paint and, using an included pad, you sand the product down. It costs $39.95 but has gotten great reviews.
    I searched and found some information and a review here: http://autorepair.about.com/od/produ...afpr081105.htm.
    It is expensive and I'm sure the same result can be achieved with much less money invested, but it's an option.
    - Brian
    2006 Acura TSX with Navi
    Past: 1997 Honda Accord LX
      rock chip repair:
      wash and dry the panel
      clean the repair area with vinegar or 50/50 alcohol water solution this removes wax
      tape off around the chip
      get a sanding stick from a hobby shop and feather the edge of the chip
      clean the repair area again
      dab a little of your favorite factory touchup paint
      let it dry and apply another dab
      what you want to do is build up the paint to fill in the chip until it is higher than the finish
      once you have it built up and slighty above the Oem finish let it cure for 24 to 48 hrs.
      then you can wetsand and buff out the repair
        Let me ask before I give out advice.. Are you looking to fill the little chip with something like "Icing". spray a little epoxy, then bc/cc and blend the surrounding edges?? Or are you just looking to fill it in with touch up paint, and do this until u have built it up???
        I think in these types of questions, I maybe should just be a spectator... .. My way of doing said repair is totally different... I use all my body shop supplys and it will be undectable at any angle or under any light.... If you are looking for this and have a compressor and gun.... I can help you, otherwise I would say you have been given good enough advice.
        Matthew
        King of Bondo
          rock chip
          Miguel
          "What you become directly influences what you get"
            Matthew
            always interested in new techniques if you don't mind sharing
              Certainly... go to the link and look at a step by step process I have written and documented for my fellow hot rodders
              BK's step by step guide to chip repair... Totally Undectable when finished
              Matthew
              King of Bondo
                hate to say it but
                mothers makes a really good product to fix rock chips.. from my experience its pretty good theres just the problem that my touch up paint is slightly darker than the colour of my car
                edit: the product is called mothers paint chip repair
                too bad meguiars doesnt make a product like that its really pretty useful if you have a honda/acura
                Patrick Yu
                2003 Honda Accord
                2008 Honda Accord EX-L V6
                  Originally posted by sneek
                  hate to say it but
                  The Mother's chip repair kit is a great tool once you get the hang of it. However, Mother's discontinued the product. It was made by Langka for Mother's. The same kit can be purchased from Langka. It is a very good alternative to wet sanding.
                  Bama
                    ahh that i did not know
                    Patrick Yu
                    2003 Honda Accord
                      you can have a body shop mix up a small bottle of touchup paint
                      I've found that you need to omit about 25% of the black (or the darkest color if the mix doesn't use black) for a good match
