I know this is off topic, but I was hoping someone could knows the answers to my questions. I'm installing a garage door opener tomorrow and would like to know what is the best way to mount the header bracket. The instructions show that you can mount it straight to a stud if it lines up with one. If it doesn't, you are supposed to add a mounting board to the wall. What I am refering to is the opener track mount that connects to the wall. Well, I guess I should get to my question. I have a concrete block home. Is it better just to mount the header bracket straight to the concrete block (using anchors), or should I mount a 2X8 piece of wood to the concrete block and mount the header bracket to that? What type of concrete anchors should I buy? If anyone has a concrete block home and don't know the answer to my questions, can you check to see if there is a wood block mounted to the wall above your garage door?
Any help would be greatly appreciated.
