Ridgid WD4070 4Gal/5HP vac cheap at HomeDepot
  • Ridgid WD4070 4Gal/5HP vac cheap at HomeDepot
    Just thought this was a good deal and pass it on.
    Was $83.97 now $69.97. Can use that extra savings towards the better hose kit
    Re: Ridgid WD4070 4Gal/5HP vac cheap at HomeDepot
    Did you find that this size was small enough to fit in the foot wells of cars while working inside a small car?
    Will it fit fairly stably on a stair and follow you down as you do each one?
    Do you have the link to the softer hose kit?
      I recently bought this also but have not used it yet. The below is on my list some day when can justify the cost:
      https://www.stihlusa.com/products/wet-dry-vacuums/professional-vacuum/se122/
      Nick Winn
      Irvine, CA
      nawinn@meguiars.com
        This is the nice 1-7/8 x 10ft hose for it. Model# VT2570 $38.97https://www.homedepot.com/p/100375877
        This is the popular Premium Car Cleaning Kit with attachments and a smaller diameter 1-1/4
          This newer model looks identical to the WD4070, but has no wheels. This might work better for you with a slightly smaller foot print without the wheels and would be more stable to work on the stairs. It’s more expensive, but comes with their Pro Hose too.
          $101.14 on Amazon.
          RIDGID 50313 4000RV Portable Wet Dry Vacuum, 4-Gallon Small Wet Dry Vac with 5.0 Peak HP Motor, Pro Hose, Ergonomic Handle, Cord Wrap, Blower Port https://www.amazon.com/dp/B011KF44YQ..._we0SEbFG3FFED
