What to use to clean oil out of threads before using LocTite?
  • What to use to clean oil out of threads before using LocTite?
    Hi everyone,
    Long time, no visit. I still do detailing part-time, but have been pretty busy with work so I don't do it very often. However, my garage is still very well stocked with Meguiar's
    I have a question that has nothing to do with detailing, but I was hoping someone here would have a suggestion about it. At my job, we deal often with bolts (usually set screws) that keep on backing out. We use blue or red LocTite, depending on the application, but a lot of times there is grease or oil in the threads that the bolt is going into. I'm assuming the LocTite doesn't do much good if there is oil or grease in the threads. Often, the bolt goes into a pillow block bearing or some other part so the threads are not easy to clean out. So, my thought was to use non-chlorinated brake cleaner to clean the threads. I want something that will clean thoroughly and quickly, and dry quickly without residue. However, my concern is, I have heard that brake cleaner can damage plastic and rubber. In the case of the pillow block bearings, it's very difficult to avoid getting the brake cleaner on the rubber bearing seal. I've wiped it off immediately without seeing any ill effects, but I wanted to see if any of you have any suggestions about whether that's a foolish thing to do, or any other suggestions of what else might work to clean the oil out of the threads. I have heard the non-chlorinated brake cleaner isn't as likely to cause damage as the old, chlorinated cleaner was.
    The other consideration is the smell. We would be using it in a gym environment often, and it's hard to avoid spraying it where others could smell it. Obviously we'll be as careful as possible, and warn people that are nearby before spraying it. But if someone has a suggestion of something that would do a comparable job and not smell so bad, that would be awesome too!
    Thanks in advance for any suggestions!
    Lydia
    Lydia's Mobile Detailing
    2007 Honda ST1300 - Silver
    Re: What to use to clean oil out of threads before using LocTite?
    Agree with using brake cleaner.
    As for any odor: you could outside, spray the cleaner into the can top, back inside and with a q-tip, swab out the offending oil and gunk.
    If you are using a boat load of spray brake cleaner, it is available in a non-spray variety...ask at a auto parts store (the commercial sales guys).
    Bill
      That's a good idea, thanks! And that's good to know about the bulk but at this point we don't use enough to make it worth it.
      Thanks again!
        Dawn dish soap and water. Strong degreaser and safe on practically any material. Agitating is always a good idea and try to wipe out as much as you can (small brush, cloth, paper towel, etc) I do this to keep threads clean on my mountain bike parts, especially brake rotor bolts that absolutely can not have loctite failure.
        Black on Black - 2007 Chevy Avalanche Z71 4x4
        Personalized Detailing
          Carb cleaner, maf sensor cleaner, I think they might have less of a smell, both dry real quick too
            Great, thanks for the suggestions! I'll try both of those ideas.
