wheel alignment after changing suspension??
  • wheel alignment after changing suspension??
    would i need to get a wheel alignment done after changing my stock suspension to Monroe quick struts?
    Re: wheel alignment after changing suspension??
    Simple answer, yes.
      thank you
        Anytime you tweak or play with the suspension, you will need one. As Selectchoice already mentioned, yes.
          That's exactly how it works.
            Even if you hit a hole in the road, brush a kerb, bump a wheel while parking, it all affects the alignment. Should be simple and cheap enough to get done properly.
