Air compressor repair
  • Air compressor repair
    The check valve took a dump on my air compressor, But it gave me the opportunity to redo my air lines to help reduce water build up in the regulator and lines. With water being heavier than air you need to pull the air off the top which allows condensation to drain to the lowest point and have way to easily drain the build up.
    I also run 2 lines, 1 through the regulator for air tools and painting and 1 right off full tank preasure for quick tire fills and drying water off cars.
    Re: Air compressor repair
    Quite a nice set-up Frank.
      Black pipe is really easy to work with.
        Hey Frank, although I don't know what I am looking at, it seems like it was an interesting project to work on. Was it too late to ask about the new 2 Year Warranty?
          LOL just a little It's about is 10 years old.
          It is just a set up to keep gravity pulling moisture down and air up for
          painting.
