Help? Powerpoint custom background/template?
  • Help? Powerpoint custom background/template?
    Hey guys and gals...
    I'm trying to put something together in powerpoint that rotates several pictures in the same spot and keeps looping them. It is meant to show a progression of the same vehicle, start to finish.
    I just want 3 pictures to keep rotating in the same spot on top of themselves as long as the slide is open. Is this possible?
    Re: Help? Powerpoint continual fading in/out pictures
    You can do it that way in the slide's custom animation timeline. Each photo gets assigned a number... put them in the order you want displayed then, add fade in & out effects for each.
    Rob A.
    '07 Kia Optima (Gold)
      I'll give that a shot! Thanks
      *It worked! You rock!
        Ok, one more question for the powerpoint gurus...
        If I want to use a nice jpg to be the FULL slide "template" per se for the entire powerpoint, how do I import it as a layout?
        Here is the link to what I want to use: PPT background!
          Re: Help? Powerpoint custom background/template?
          Ok. Go to slide master and from there insert the background that you require. Go back to the normal view and all your slides would display the selected background. Gosh, I used to train folks on Ms Office...now I'm kinda forgetting all the things
            Are you using 2007?
            In '07, you can right click - "Format Background" - "Picture or texture fill" - Then you can select the picture from your files.
            Chris
            Dasher Detailing Services
              Awesome, thanks guys!
                Shine your car or get help on a computer program.....
                The talent of this crew (MOL) is amazing!
                  The Slide Master, sounds like a super hero or a villain? Do they have a cape and a mask?
                    No, but I bet that have gatekeeper as a sidekick... (pardon the Ghostbusters pun).
                    Rob A.
                      Great. Glad to hear. The other thing you can do is go to:
                      Slideshow > Set up show > check the box "Loop continuously until ESC".
                      Rob A.
