Is this film on the inside or the outside or both?
Some types of film or gunk that build up on glass requires more than just a liquid, spray-on cleaner to remove the film. M04 Heavy Cut Cleaner is pretty good for this but so is our new M105 Ultra Cut Compound.
I have not personally used our new Ultimate Compound on glass but I suspect this will work also and will be available starting in January.
So if you need a product right now you can opt for the M04 or the M105
If it is something other then spotting, I like to give the exterior windows a good claying before I clean them. Works wonders on the exterior. For water spots, I have been using #4 for a while now.
