I know a lot of people here drive stick and everyone is pretty friendly, so I thought I'd pop a question.
I am 21 and currently drive an automatic. When I was 16, I messed around with a friend's manual and was doing pretty decent with it. I was impressed for 16. Last year, I tried driving it again and stalled twice. I haven't touched it since. hehe.
I have read a lot online about the techniques and understand it for the most part. I also understand that stalling is normal at first and it will happen. I have a cousin with a manual so I think I'll see if he can take me out. But I have a few questions I was wondering someone could answer.
- Alright, so you start the car while depressing the clutch. Once it is started, can you release the clutch? Then when you want to back out of a parking spot in reverse, let's say, do you need to do utilize the clutch and gas as if you were driving normally out of first? Also, do I need to hold down the clutch when putting the tranny into reverse or is that not necessary? All the while, I have my foot on the brake, correct? So, the sequence would be clutch in with foot on brake, start car, clutch in and move shifter to reverse, foot off brake and hit gas while clutching out. Once out of spot, clutch in, move shifter to 1st, clutch out while giving gas. Is that correct or am I making stuff up?
- Let's say I'm driving on a highway in fifth gear. I see a stoplight ahead and will need to come to a stop. What do I do? Do I clutch in, pop it in neutral, then clutch out with gas and then coast to a stop? I can also stay in any gear until around 1,500 RPMs, then pop it into neutral, right?
- The same technique is used for downshifting and putting it into neutral, in terms of clutch in and gas while clutching out (as I mentioned above)?
- Let's say in the above situation the light turns green before I come to a stop. I'm already in neutral. How do I know what gear I need to go back in since I was previously in fifth? Does it depend on how much I slowed down?
- I come to a stoplight and am stopping. After stopping (clutch in and then to neutral while giving gas, right?) do I take my foot off the clutch and keep it only on the brake, as if I was in an automatic?
- How do you know when to downshift? I know when on a highway and you need more power, but what about when making turns? It seems so confusing to me that I may be in a gear, make a turn while braking, then may need to downshift because the RPMs are getting too low for that gear.
- What happens when you stall? Do you clutch in, put the car in 1st, and clutch out while gassing?
When I park, I understand you need to put the car in gear. So I put it in 1st or reverse if I am facing uphill or downhill, respectively? What about if on flat land?
I know the questions are confusing and jump everywhere (and my assumptions could be completely wrong), so I apoligize in advance.
Also, if anyone has any great sites to visit for more help or videos (that would be a help, too, actually seeing it in action as opposed to reading it) please pass them on.
How did everyone else learn? Are there driving schools which give courses in driving a manual transmission? I know how to drive, just not a manual.
Thanks again.
Thanks again.
