To Bead, or Not To Bead...
    Re: To Bead, or Not To Bead...
    Originally posted by Ganesa View Post
    is NXT 2.0 suppose to sheet the water off or more likely to bead??
    sheet right??
    It will bead up on horizontal surfaces, and with vertical surfaces or running water it will tend more to sheet water away.
      thanks, that means my car is still well waxed now
      Ganesa,
      Toyota Vios '05
        I'm with Ron. I do want protection, but no beading. I would like the water to roll off the surfaces with very little resistance.
        Earlier this year I had a good coat of 26 on my Camry and we had one of our infrequent rainstorms. After work I was marveling at the fantastic beading on my car . I figured it would blow off during the 2 1/2 mile drive home. No such luck. There was still 90% of the water left beaded on my car.
        By the way, given the choices, I had to vote for Melange.
        George Carlin
          Can't blame ya there! When you get the ability to fold space, let me know... I may have a trip in mind.....
          --VoicesInMyHead--
          • #20
            I like the look of the beading.. but like you said I would like it to blow off easily when driving.
            • #21
              I'm with the OP. I've often said that beading is a pain for that same reason.
              I just don't think there is much I or anybody can do about it, so I just live with it.
              • #22
                Where I live (Philippines), both beading and sheeting products don't work very well. The dust combined with the sticky grime from car exhaust turns my car's paint into a mobile post-it(tm). Whenever it rains, sure it beads (or sheets), but after the rain stops, most of the car is still covered in water. When it dries, I get sticky white spots.
                Whether it be by beading or by sheeting, I'd really want to minimize the time that water spends on my car's paint.
                That's why Melange gets my vote!
                • #23
                  eric son - perhaps you should look into nanotechnology coatings (Lotus effect)
                  • #24
                    What is "Melange"?
                    • #25
                      If you live near airports or large factories all the stuff in the air comes down in the rain and lays on the surface of your car in that little droplet of water. As it sits there on the surface and the sun comes out the droplet acts like a magnifying glass and burns those chemicals into your paint. ACID ffice:smarttags" />RAIN, Remember as a kid playing outside with a magnifying glass and burning things?
                      • #26
                        A quality wax/sealant like M21 2.0/NXT 2.0/Ultimate Quik Wax will leave a surface that will bead on horizontal surfaces, and if the vehicle is driven the water should bunch together and sheet away. The sheeting will naturally occur on the sides of the car where gravity can do its part.
                        MKs statement is true. Water (especially small amounts) will bead on a relatively horizontal plane and water will sheet (especially large amounts) on a relatively vertical surface . Beading and sheeting are both the same thing, it signifies that the surface is resisting water.
                        I grew up in the Philippines where "taro" plants are abundant. Taro leaves are particularly resistant to water and you will clearly see that taro leaves tend to bead water if they are horizontal and they tend to sheet if they are vertical.
                        Check out this video of the beading/sheeting action of the taro leaf. http://www.youtube.com/watch?v=vPM_7...eature=related
                        FYI: taro leaves have microscopic hairs that lift water and prevent it from sticking to the flat surface of the leaf.
