Poll: Car Washing Style?
When you wash your car or a customer's car,
Meguiar's recommends starting at the top and working down, for example starting on the roof of your car and working your way down the car.
Some people like to wash the wheels and tires first and after washing and rinsing the wheels and tires then they start at the top of the car and work their way down.
The reason for this is because if you wash the car starting at the top and working down, you have a wet car with water on the paint in the process of drying. While this water is sitting on the paint drying and potentially leaving a water spot, you're washing 4 wheels and tires, this takes time and while you're doing tis some water may dry on it's own before you can finish the wheels and tires.
If after washing the car you then dry it, and now start washing the wheels and tires, you usually get water spray on the paint and this could include dirt from off the wheels as you were spraying them, so now you'll have to wash and rinse the affected area again.
So for the above reasons, some people will wash the wheels and tires first, then wash the car. By doing it like this you don't have to dry the paint twice, nor rinse any of the paint a second time around the wheel wells. Then immediately after you give the car a final rinse you can being drying the water off the car. Since you're finished with the water hose and you won't be spraying water any more, then you won't be getting the car wet again and you should have enough time now to dry the water of the car without any risk of water spotting.
Personal preference.
- Do you start at the top of the car and work your way down?
- Do you start with the wheels and tires and after you're finished with the wheels and tires you switch to the exterior body starting at the top and working your way down.
- Or do you have some other method to your madness?
