Car Drying Method
  • Car Drying Method
    What methods/products do you use to thoroughly dry car after its bubble bath?
    344
    The Absorber
    27.91%
    96
    Meguiar's Water Magnet or other Chamois
    56.69%
    195
    General Towels
    11.34%
    39
    Driving It On The Highway
    4.07%
    14
    Re: Car Drying Method
    A Water Magnet isnt really a chanois....
      Right now I use a waffle weave for drying. One of these days I'm going to put the hose on the blower port of my wet/dry vac and give that a go.
      Scott
        Yup true it isnt but I lumped it as an either or.
          After my final rinse I take the nozzle off the hose and just let a gentle stream of water run over the entire car. This collects up all those pretty little beads of water and sheets 80-90% of the water off the car. After that I take a couple of Water Magnets to what's left.
          This process works great on a well waxed car, and even better on one treated with Ultimate Quik Detailer. I can't wait to see how NXT 2.0 or M21 2.0 helps this process.
            I do the same thing (see I do read what others do )
            Whats left, I use my Meguiars microfiber towels to mop up the rest.
            Aaron
              I use a slow flow from the hose then use some microfiber towels.
              AeroCleanse, LLC
              www.aerocleanse.com
                I sheet the water to get most of it off then us the absorber, then i go over the rest with a waffle weave.
                  After I sheet the water off, I use absorber, then a Marine water magnet. On the glass I use the regular water magnet after the absorber.
                    Sheeting method then Water Magnet. Sometimes if its too hot to sheet, I'll use the blower on the vacuum to get all the little cracks and crevices cleaned out.
                    Ryan
                      I actually use the "Water Sprite" but it's like the absorber. I use waffle weave MF towels too. I guess it depends on the car and weather or not I will be polishing it after.
                      Rasky's Auto Detailing
                        After sheeting the water over the car,
                        I take my modified electric leaf blower to blow off the excess H20 and then do a quick walk around hitting the nooks and crannies.
                        Next comes the absorber, then MF waffle weeve and finally the plush microfiber to do a final buff.
                        p@
                          Stream off with nozzle-less hose, leaf blower, then water magnet.
                            Water magnet most of the time
                              I go for a drive around the block. 5 mins and nothing touches the surface.
                              Edit: Probably should add that the car is white and never gets water spots.
                              Daily Driver - 1990 Mustang LX - 5.0L
                              Doesn't Leave Garage - 1995 Mustang GT - 5.0L
