Ultimate polish issues
  • Ultimate polish issues
    Every time I use meguiars ultimate polish I find it difficult to remove. For example I
    Re: Ultimate polish issues
    Only thing i can think of is: You use to much, you let it sit too long so it dry, the surface you try to polish isnt smooth enough.
    I never had any issues, and am kinda nooby
      Hi Kial91,
      Sorry to see your post was cut off. Feel free to continue when ready.
      Thoughts:
      Are you applying Ultimate Polish by hand or machine?
      If by hand, what type of applicator pad?
      If by machine, which machine & which pad are you using to apply?
      How big of area are you working in at a time?
      For how many passes or for how long, would you say you are working the product in?
      Are you working on a cool surface in the shade?
      Are you using a premium, clean microfiber towel for wipe off? If so, which kind?
      From here we can further diagnose any adjustment in application technique. It is possible the product & paint just don't like each other. Unfortunately it happens. After the above questions are answered, we can work with you to come up with a next step.
      Nick Winn
      Irvine, CA
      nawinn@meguiars.com
        Sometimes you might find that Ultimate Polish will leave a glossy "deposit" that is almost impossible to remove.
        It usually occurs on the outside edges of the section being polished.
        I find this happens when the paint is sort of "dry", or "sticky", and/or when I haven't shaken the bottle enough.
        When this happens, simply go over that section again with a little fresh product on your pad, go over the spot again until it "reactivates" and wipe off with your microfiber towel.
        I haven't had this happen in a couple years, and I use Ultimate Polish a lot.
