Where would mirror bright fit in if at all??
  • Where would mirror bright fit in if at all??
    Love meguairs range and my current process for a good detail is
    Hyper wash pre wash
    Soft wash gel
    Ultimate compound (tried the 105 but found it hard going) *** compound not everyrime
    It used to be ultimate polish but i a really liking 205 and moved over to that
    Then ultimate wax
    With a quick detailer afterwards (just started using mirror bright qd)
    Which steps would the mirror bright polish replace if any
    And in terms of durability would i be as well applying ultimate wax after mirror bright polish
    Can mirror bright be applied by da if so would that be medium speed with a polish pad (chemical guys orange )
    Sorry for all the questions but i like to make sure i am doing the best practice when detailing my car
    Re: Where would mirror bright fit in if at all??
    I am sure you are referring to the polishing wax. It falls into the cleaner wax category. It's an abrasive cleaner wax as it contains SMAT abrasives. It's correction can be adjusted depending on the pad used.
    If you are looking for an All In One then this would be what you want.
    A dedicated polish or compound will give better correction.
    The durability is supposed to be close to ultimate wax.
      Thanks k for the reply
      Would i be wise to go over it afterwards with ultimate wax then or are you saying it takes place of polish and wax steps
      Sorry for the probably obvious question.
