Weird results from Ultimate Liquid Wax
  • Neo Fender
    replied
    Re: Weird results from Ultimate Liquid Wax
    Ultimate Liquid Wax can streak. Especially if it is applied to thick. Same with the blotchy appearance. It can also appear blotchy on a hot surface. Were you applying it in the sun?
    With ultimate wax, it should be applied thin. A little goes a long way. It can also be applied to the entire car or removed after 3-5 mins if working per panel. It will not haze like a traditional wax. Try it again but apply it thin.
    Applied in the shade per my OP. I applied it thin (or at least thought so - to the point of not being able to tell what color the liquid was). I worked in sections, waiting 3- 5 minutes per the instructions and in same cases waited longer to remove.
  • The Guz
    replied
  • Neo Fender
    started a topic Weird results from Ultimate Liquid Wax
    Based on numerous reviews throughout the Internet, I decided to try Ultimate Liquid Wax on my new vehicle. I've had very good results from Meguiar's Cleaner Wax in the past on other vehicles and was expecting at least a similar if not better result. I bought my vehicle new less than a month ago and it was in the showroom when I purchased it. I spent over an hour washing it thoroughly with Meguiar's Deep Crystal Car Wash and towel drying it. Vehicle was in the shade and the temperature was in the 70s. I applied the product using the included applicator per the directions. When removing it, I noticed in every area, it left a blotchy appearance. In many instances, it almost had a slight, oil-like appearance at the beginning of removal. I re-washed a section of the vehicle and much of the blotchiness went away. I reluctantly finished the vehicle but it looks much worse than before. I tried the product on another car and had the same results. Very disappointing, considering the cost, time and effort involved. Would appreciate any constructive feedback on what the problem(s) may be.
