yellowed vinyl / plastic window
  • yellowed vinyl / plastic window
    Will plastx make yellowed vinyl / plastic convertible window new again?
    Are there any prep steps I should do behore applying plastx?
    Extreme Radiance Detailing
    2001 C5 Corvette - Black
    2010 LT2 Camaro - Victory Red
    Re: yellowed vinyl / plastic window
    Well, as for the yellowing, maybe. Depends on if it is the surface, or all the way through. Can also try UC for a stronger cleaner...
    As for prep... you may need to apply some pressure, so if you can remove and work on a surface, or try to have something hard behind it, someone holding something, etc.
      I tried M205 with a foam polishing pad on a Jeeps plastic windows and saw moderate improvment. From what I understand PlasticX is somewhat similar to M205[both being polish] yet much milder. I only did a quik run on the exterior and probably would've continued to see improvment if I had spent more time on it.
